Mvave Chocolate Plus USB Host
Working fom me too
This helped me:
In the Nano Cortex app, it’s set to Exp Pedal, because that’s only for the 1/4" port. The USB-C port is ONLY MIDI or power delivery.
So it wasn’t easy, but you update the Chocolate Plus with push updates manually through a weird updater app (SincoOTA on iPad) and the files are on cuvave.com (in the Mobile Firmware tab)
Then, you can program the Chocolate Plus with an app called CubeSuite (on iPad again). That app is extensive and you can do so much with it. However, I don’t think the Nano Cortex can do CC controls :frowning: (someone please correct me if I’m wrong!)
Then, you set it all up. Expression pedal through the 1/4" EXP/MIDI port, and the Chocolate Plus has to be POWERED by a USB-C cable. Then put it in host mode (the switch that goes U/O/H), and connect from the USB-A host port to the USB-C port of the Nano Cortex using an A-to-C cable
I just use it to change presets, so the you have eight to pick from at a time. And the Chocolate Plus can change banks, so you can theoretically chops any of the 64 presets if you are quick enough with your feet
It’s in https://www.reddit.com/r/NeuralDSP/comments/1h9bacl/trying_to_control_nano_cortex_via_usbc_from_a/
