More Splinter/mixer options
I wish we have the option to mute in/mute out an effect while using a parallel routing. Also, more flexibility with mix level and imput gain to Reach unity level.
Did I miss something? How you guys set Up your parallel effects like delay and reverb?
Quote. The bypass type on Fractal products are very useful when used in parallel
Since a mute in any block will mute the whole lane, it doesn’t matter where in the chain it happens. As a work-around, you could insert something simple like a utility gain block. Turn the gain all the way down so that whenever you turn the block on, it mutes that lane. Not optimal but it’d get you by.
