Hey folks. I initially had trouble installing the plugin, and my DAW wouldn’t scan the .dll file so I tried deleting everything and re-installing, and in the process the .dll file got canned. Is there a way to re-download it? I’ve tried using the setup wizard and re-downloading the plugin but I’m not having any luck getting that file back. Any help would be appreciated.
Hey @DarcMurkee. Try reinstalling (selecting “complete” installation), and then check if the plugin files are correctly installed. If you’re looking for the .dll file, it should be located at: C:\Program Files\VSTPlugIns
If the plugin file is already there, then you will need to re-scan your plugins in your DAW.
