Hi everyone, I´m facing some issues with controlling the Misha Mansoor X plugin in the DAW VST Live from Steinberg.
I would like to control the plugin with type CC Preset but the plugin is not changing the effects. With older plugins like Nolly or Gojira everything works perfect with the exact same setup. All plugins are installed as VST3 but I tried also Misha Mansoor X as VST2 with the same results.
Is this issue on Steinbergs side or on the plugin itself?
Best regards
Foradh
Do you have any other type of DAW that you can test Misha X with?
Hi, I have just checked the plugins in DAW Reaper and here it is the same issue. Nolly and Gojira are working as expected, while Misha Mansoor X is just not responding to any midi commands. So it looks like a plugin issue
Gotcha. At least you have more data about the problem. Best advice is to go ahead and contact NDSP support, it could be a bug.
Hi, I have fixed the problem with the NDSP support. Misha plugin needs to have a value above 0 coming with the CC# command while Nolly and Gojira are working also with 0.
Best regards
Foradh
