Well the question is actually in the titel. Iam using Cubase as my DAW and I have an FCB1010 footcontroller. The VST iam trying to connect to my midi controller is the Archetype Abasi.
I can program the midi map and switch presets successfully with the program but as soon as I run the plugin as an VST in my DAW the plugin doesnt respond to any of my midi commands( and yes the controller is conected and visible in the DAW). I just cant figure out how to map those midi inputs correctly, I would be really happy if someone could help me.
I can also make some screenshots if its needed !
Yeah… I know that I can do that but all I can do are some quick controlls to turn of some Archtype pedals/amps. I can’t find the setting for changing the preset.
Well thank for making this video it helped me a month ago ! I know how to set up the board if I use the plugin as a stand alone but as soon as I start the plugin in Cubase nothing of those things that are mentioned in the video work anymore, even if I have my presets set up correctly.
