I was under the impression that Cali was supposed to have a ton of of custom IR’s including some done by Adam Getgood. I watched a video of a gentlemen on youtube demoing it and his came with a ton. But when I hit the load custom IR button I cannot find any. Are they hidden in a file somewhere? I even did a search on my HD for all files ending in .ir and the only ones that show up are the ones I already owned.
Hi @cameronm79. Additional IRs are installed on the following locations:
Windows: C: \ ProgramData \ Neural DSP \ Impulse Responses
macOS: Macintosh HD \ Library \ Neural DSP
They are .wav that explains why they didn’t show up. Thank you so much!!!
@cameronm79 No problem!
Hi i cant find the custom IR either, i have win 10 and tried to make a clean install with newest install file, cant you share the file please. I dont have folders called program data and impulse responses
Hi @kim.nielsen. You probably need to enable “Show hidden files, folders and drives” first.
Thank you, that did the trick
Are there IR wav files for the Granophyre? There are none in that directory.
@schivosa Only the Cali and the Nameless have additional external IRs.
