I need to use ping pong delay in a song and even when I choose stereo delay effect on quad cortex, it doesn’t make any difference. I want it to sound like the effect is being panned.
Right now I use input 1 guitar and output 3 of QC to the audio interface. Should I also connect another output to the audio interface?
And if that’s the case, should I do anything else on Logic too, like adding an extra channel?
Also, keep in mind not every ST delay is a stereo EFFECT, some (like Simple Delay) are a Stereo BLOCK.They allow a stereo signal to pass thru the delay and remain in stereo, but the Delay itself does not ping-pong or pan. So even though it says “ST” in the device name, that particular Delay is not going to pan.
Hope that makes sense
