I have no idea why. But it just isnt working. It worked fine the last time I played.
In the drop down menu, the outputs for 3 and 4 are identical, but I only hear sound from output 4
I am manually toggling the cable between output 3 and 4… when plugged into 4: sound. when pluuged into 3: nothing (I think I MAYBE heard a very faint noise when gain was very high)
Long press on the output and make sure the level isn’t muted or level is too low, also try creating another preset using those outputs and see if it resolves. Usually muted channels are the culprit and or using splitters and mixers configured incorrectly. Worst case, email support@neuraldsp.com and they will get you sorted quickly.
It’s not silly. I had 2 amps that I swore were broken and in need of tubes. It was the cable. It was the one thing I didn’t check because it was brand new. Sometimes it’s the adapter or the power strip and that one particular place that I have it plugged in is not working.
