Global Impulse Response
EQ curves can be converted into impulse responses. This means I can make a custom IR of headphone correction software, such as Sonarworks, and load it as an IR on the Quad Cortex. This lets me use my headphone correction curve directly on the Quad Cortex.
Currently I have to use an IR loader block on every preset, which gets very tedious. Ideally, I would like to be able to load the IR globally, similar to the global EQ section. Being able to choose which outputs the IR is applied to would also be great, again similar to the global EQ.
Essentially, I want the exact same functionality as the global EQ, but in the form of an impulse response.
Not exactly what you’re asking for, but check out this existing request:
