Expression pedal still affects new block after effect change
Hey everyone — not sure if this is just me, but this felt kind of dangerous so I wanted to share.
I was using a Nano Cortex (OS 2.1.0), and had my expression pedal mapped to a Volume block in Pre FX2. Later on, I decided I didn’t need the volume control anymore, so I removed the Volume block and replaced it with a Graphic-9 EQinstead.
Everything was fine… until suddenly, while playing, I accidentally nudged the expression pedal — and boom :collision:
Massive volume spike. The meters in Logic shot up into hard clipping, easily +20dB. It scared the hell out of me and almost blew my monitors.
Turns out, even though the Volume block was gone, the expression assignment didn’t reset. It was still mapped to Pre FX2 and now seemed to control the EQ’s output or something else — even without showing any active link.
Not sure if this is expected behavior or a bug, but it’s definitely not intuitive. I feel like replacing a block should at least reset or warn about old expression mappings. Otherwise, you end up with this ghost connection that can ruin your day — or your gear.
Has anyone else run into this?
I’m not a native English speaker, and I’m also not very familiar with Western forum culture.
I asked GPT to help me write this post as clearly as possible.
Please forgive me if anything sounds awkward or inappropriate — I truly didn’t mean to offend.
Thanks for reading!
Welcome! I’m curious if you saved the preset after removing the volume block? I haven’t used an expression pedal with my Nano yet so unfortunately can’t test / try to duplicate this issue. It could be a bug and if so, I would suggest emailing support@neuraldsp.com so they can at least tell you if its expected behavior or a bug and hopefully provide resolution.
Iirc your expression pedal is assigned to the fx block and not the fx itself. So when you changed the fx in the block with expression pedal the pedal still controlled the “amount” value of the block, which translated to volume in both setups.
