Expression pedal randomly locks at 50%
Hi there, I’ve been using a Moog EP-3 expression pedal on my Quad Cortex for some time now, and it randomly stopped working and stays locked at 50% no matter what position it’s in. Even the limiting knob on the side changes nothing. I switched to the other Expression pedal input, and it worked for a few hours, then started having the exact same issue right after. I’m not sure if this is a problem with the pedal itself or if it’s with the Cortex. Thank you.
Welcome! I specifically use the EP-3 and have recommended that EP to many on this and other forums. That said, I have never experienced that issue (or any issues) with the EP-3. I would check your TRS cable as that may have become faulty and would be easy to validate. Have you tried both EP ports?
If that doesn’t resolve, you could try a backup/factory reset and restore. Ultimately you can always reach out to support@neuraldsp.com and let them diagnose.
Hey, thanks for the reply! I’ll order a new TRS cable and see, as I checked both ports, and while when I switched, it worked initially, it stopped after a few minutes and had the same issue. So maybe a short in the TRS cable.
