CorOS Version: 3.1.0
Describe your issue:
When I assign any expression pedal X1 or X2 to Doubler (or Plugin Doubler) block’s Bypass parameter either with Heel -Toe or Switch option, blocks bypass assignment works after saving it that way BUT does not react anymore after reopening the preset. The assignment can be saved and seen on Expression pedal assignment window. However, it does not do what is expected. It only works again when I reassign and save it without quitting the preset. When I try the same thing with other blocks like delay, I encountered with no problem for now. But Doubler has a bug with this.
- Assign Bypass state of Doubler/Plugin Doubler to X1 or X2 with Heel - toe or Switch option.
- Save it. Try expression pedal to see that it works.
- Change preset and come back to see that Doubler does not react to Expression pedal anymore.
I expected this to happen:
When I load any of my presets, I would love to see that my expression pedal assignment work well.
- I have tried Doubler or Plugin doubler block.
- I have tried X1 and X2
- I have tried using block in different rows with different side-chain triggers.
