Delay Blend behaviour
In making a dotted 8th delay i noticed something odd with all the delays;
an even mix of dry and wet is 82.5% and the dry and wet are slightly lower in volume than dry alone when mixed evenly.
this is bizzare - normally 50% would be both at unity gain.
instead, the dry stays at unity until ~80% and the delay stays below unity. then as you approach 82.5% the dry drops to the same level as delay and then at higher settings the wet becomes unity and dry goes down. this seems crazy to me coming from scenarios on other modellers where effect and wet both at 100% would both be at unity, or if its a blend knob then 50% should be unity for both. and the spanner in the works is the QC cant even do both at unity…
Other people have discussed delay mix in this thread:
