Defined expression pedal assignments do not work
QC SW version: CorOS 3.1.0
Cortex Control version: CorOS 1.2.0
I first noticed that expression pedal assignments would get lost when defined from Cortex Control. Now I’ve encountered another issue: assignments defined directly on the unit appear correctly in the UI, but they don’t actually work unless I unassign and reassign them first.
I would guess this behavior can be reproduced fairly easily by assigning the pedals from the Cortex Control software, then closing the software and checking the unit itself.
This issue occurs occasionally — not every time, as far as I can tell.
This might be the same issue as " WAH Bypass with Expression pedal does not work after restart".
