Default scene should not be affected on save
Hi! It would be nice to have the possibility to set a default scene within a preset, no matter what the last saved scene was.
When I select preset 1, I’d like to see scene E as first selected scene. But if I jump to scene F and press Save, now scene F will be the first scene proposed when i select preset 1.
Default scene for the preset is then set every time a Save is issued on current scene. That’s a bit annoying since it will force to save twice almost every time (if you are not editing your preferred default scene): 1 for the parameters change and 1 for setting back the default scene.
You don’t have to save twice, FWIW, you just have to remember to flick to your preferred scene before saving.
If I move to another scene without saving first I loose the changes made on current scene.
You won’t, though. Moving to another scene shouldn’t reset your changes in the previous one. I do it all the time
I use “Do not overwrite bypass state…” on CorOS 2.0.3.
Select scene A, disable a block and save. Then enable the same block. Then select scene B and go back to scene A: the block is disabled as expected.
