Cortex Control does not work in macOS Sequoia
CorOS Version: 3.0.1
Describe your issue:
Attempting to run Cortex Control on macOS 15 Sequoia, it crashes occasionally on startup when loading preset (but not always). Also, the UI no long updates in response to mouse click events once an edit has been done in Cortex Control.
  1. Instal Cortext Control (latest version) on macOS 15
  2. Start Cortex Control
  3. Notice that Cortex Control often crashes when loading preset…
  4. If Cortex Control does load successfully, notice that the UI is responsive and updates as expected
  5. Do some edit in Cortex Control: I tried updating a preset name, or adding a block. Notice that the UI is still responsive to mouse events, but the UI display no longer updates.
I expected this to happen:
I expect macOS 15 to be supported, that Cortex Control doesn’t crash, and that the UI remains responsive and updates while making edits using Cortex Control.
  • When Cortex Control display is not updating in response to mouse clicks, Quad Cortex does respond and display properly.
I’m on Sequoia (Mac Mini M2) and my Cortex Control works just fine, been using it all afternoon. Actually, v1.1.0 all afternoon, just updated to v1.1.1 and it works fine as well (seems to start up faster actually).
Must be something else going on with your setup.
Turns out it was the power supply I was using. I appears to be injecting some noise into the USB connection making it unstable. I switches to the QC power supply and all is working fine. The power supply was https://www.amazon.com/dp/B0B9R5R3C2?ref=ppx_yo2ov_dt_b_fed_asin_title
Glad you sorted it out, and that’s good to know about that power supply !
Hey, that power supply is listed as having a 2.5 mm end. The QC needs 2.1 mm for power. Did that replacement power supply feel loose by any chance?
They both measured 2.15 mm. Must be a typo in the add.
It is unfortunate that this problem is repeated… It is clear that there is a fundamental problem with the QC boot sequence… Even Sonoma has a boot probability of about 60%… They said it was due to poor USB communication, but once fixed:… It has recurred many times. No matter how great the software is, if it doesn’t boot, what’s the point?
Been in contact with neural;
Appreciate your frustration. The developers are working on a fix as mentioned, and this will come in the form of a software update, so we ask for your patience until the fix is released.
Thank you, have a nice weekend
Best regards,
Neural DSP Support Team
Thanks for your reply.
I know it’s a lot of work fixing bugs, but good luck. I think the fact that you are degrading means that you simply don’t have enough automated testing. Take the weekend off (it’s only Wednesday) and get rid of those pesky bugs!
Unfortunately using the factory power supply didn’t help me. I have been normally powering it with a DC7/Crux but no matter what power supply, no matter what USB cable, it ALWAYS crashes at the last loading block in the startup screen. Every now and then it makes it into the main interface but almost immediately goes back to the loading screen and crashs on the last loading block.
Works flawlessly with a windows 11 computer and worked flawlessly before upgrading to Sequoia.
One other thing I’ve notcied is that Rode Central (the app used to manage my lav mic’s) also crashes EVERY single time I try to open it once I connect the lav mic usb case to the macbook. The software opens fine and sits there asking for me to connect the microphone charging case but once I do, the app immediately crashes.
It’s almost like there’s some weird USB bug going on that the software doesn’t like.
Its possible macOS introduced a defect around USB communication error processing. I have seen macOS USB issues in the past.
Working fine in Sequoia (15.0.1) for me. I’m going direct not via USB hub
I use an OWC Thunderbolt hub, and it’s working fine too in 15.0.1. But I did have to use a different power supply in QC.
As mentioned, Cortex Control mostly works on mine with a Mac Mini M2 on macOS 15.0.1. I’m using a Ugreen powered USB 3.0 hub I bought off Amazon btw.
I do sometimes have crashes on occasion, seems to be when I start up the software while the QC is still booting up, but I’m not positive it’s the reason why as most of the time it works fine.
I’m experiencing issues running Cortex Control on macOS Sonoma 14.5 (M1 Pro MacBook Pro). Here’s what typically happens:
1. I start Cortex Control.
2. It gets stuck on the initial connection screen, even though my Quad Cortex is properly connected.
3. I quit Cortex Control and restart it.
4. After restarting, one of two things happens:
• It gets stuck endlessly loading presets.
• It works as expected (almost by chance).
Every day, I have to go through this frustrating cycle of opening Cortex Control, quitting it, restarting, and hoping it will finally work.
I have same issues on my Mac M1 Max Sequoia 15.3 (24D60)
Few attempts to connect QC and randomly I get Cortex Control working
@boochamoocha
Ensure you have the most current version of CC downloaded and installed. There were a number of macOS bugs resolved over the past few updates so ensure you are running the most current. Worst case, email support@neuraldsp.com so they can log your issue and help provide resolution.
I’m starting to get more glitches and crashes on my setup which is a fairly old iMac. It previously ran smoothly with no crashes. Not sure why it’s having these problems, nothing has changed in my rig.
i have the most recent version of both CC and Sequoia and no issues at all. (Mac Mini M1)
Same here. Getting really fed up with this and the multiple other problems I have with the QC (like no sound on startup)
