We are pleased to announce that CorOS 2.2.2 is now available!
Download it via Settings > Device Options > Device Updates on your Quad Cortex once connected to Wi-Fi. We recommend that you create a backup before updating your firmware.
Changelog
Fixed
An issue where an incorrect parameter value would be recalled on Preset load for parameters assigned to an expression pedal treadle not positioned at its minimum range.
An issue where the bypass state of a device assigned to an expression pedal would be briefly incorrect after changing Presets if the device is present in the new Preset and also assigned to an expression pedal.
Nowadays we see frequent updates. However those only include some bug fixes and plugin compatibility issue as far as I follow (which is of course a necessity) We users also hope for some game changing updates in advance which include some crucial details demanded as “feature requests” by owners.
Installed and no issues. Exp pedal travel is better. I modified my presets to use scene changes to control the WaH on/off state instead of heel/toe so can’t test that.
I have the switch output on my ME pedal going to my Nektar Pacer which sends cc’s to alternate between two scenes identical except for opposing wah and volume block states. Preset loads with the volume block on wah off, press the switch and it turns the volume block off and the wah on. So it acts as a vol/wah pedal. That frees up my other exp pedal which I am using to control going clean to some gain.
did you update BOTH the QC and Cortex Control? You have to update QC first, directly from the unit. THEN update CoCo from the NDSP downloads page, in that exact order.
they should probably put that in the email/instructions, etc
How about the developers save a bunch of new and improved effects like Reverb or Chorus, then only release a bug fix when there’s a sound update?
That way the user gets positive feedback from doing the update instead of wondering if they should go back to tube amps or the latest digital offering from someone else.
I’m still a fan and have gigged extensively with my Quad, but this is weak, getting on my nerves.
I wouldn’t want to have to wait for features that may be going through development and QA when an important bugfix is required. They are right to release hotfixes outside of the normal update cycle. Nobody wants to wait for a fix to the expression pedal issues while they put the final touches on other features that may add additional delays and even introduce new bugs.
