Cioks with 4 cable method vs Crux temperature
I don’t know if I’m the only one but my Cioks DC7, which (only) powers my QC via the 4-cable method, gets very hot. Because it’s mounted directly under the QC it heats it as well (see pic below). So I decided to order a Cioks Crux to see if this would improve thermal behavior.
I measured the surface temperatures of the Quad Cortex, DC7, and Crux using an infrared thermometer. For each device, I scanned the entire top surface and recorded the maximum temperature observed. I used the same preset for both scenarios and let the board sit for about 2 hours (with a several hour cool down period in between) before taking measurements.
The obligatory shot of the underside of my board (Crux installation not shown)*
Measurements
Room temperature: 22 °C (72 °F)
Using 4-Cable Method:
  • Quad Cortex: 39 °C (102 °F)
  • Cioks DC7: 47 °C (117 °F)
Using Crux:
  • Quad Cortex: 37 °C (99 °F)
  • Cioks DC7: 43 °C (109 °F)
  • Crux: 44 °C (111 °F)
Conclusion
My takeaway is that the Crux doesn’t really seem to make a noticeable difference in terms of heat generation. I’m honestly surprised by how hot both the Cioks DC7 and the Crux get, given what they do. I would have expected them to stay significantly cooler.
I would have preferred it to run cooler, but I don’t think the heat is in reality problematic for my use case. It might be for you, if you are on a stage in the blaking sun. That said, I’ve decided to return the Crux because it is no solution to the heat issue and I don’t need the extra power outputs from the DC7…
PS: I already tried another Cioks (wanted to ensure mine was not an anomaly)
PS2: QC CPU usage for this preset 58%, screen brightness at 12
I use the SOL in the same way (4 cables) and never noticed high temperatures. I’ll misure in the coming days and let you know.
Ok, scenario after 2h:
  • home temperature 21 °C
  • Preset: 54% CPU
  • QC: 27 °C
  • Cioks SOL: 34 °C
The SOL powers the QC and the Boss SY-200
Thanks for the info about the SOL!
It appears that the Cioks SOL is a more thermally efficient device than the DC7. Perhaps because the DC7 has more outputs (7 + USB) and can deliver 48W as compared to the SOLs (5) at 30W. Who knows…
Either way, the Crux doesn’t alleviate the heating ‘issue’…
PS: Just to compare I measured the Neural DSP supplied power brick with the same preset and QC setup: 37 °C (99 °F)
Decided to measure the QC surface when powered with the original power brick with the same setup as the other tests:
  • Original Quad Cortex power supply: 35 °C (95 °F)
It’s weird that with no extra heat generating devices under/near my QC it runs 8 °C hotter than yours… I have one of the older models FYI
FWIW
I don’t know, I can’t explain. I got my QC in April 2025. I placed it on a Pedaltrain Metro 20.
is there a guide to setup the 4 cable method with QC mini? i’m about to get mine and would love this info!
