Capture IR´s from Fractal FM3
Hello everyone,
I have been using a Fractal FM3 until now and have switched to the QC because it is easier to use. I would like to take my favorite IR’s from the Fractal with me and have tried to capture them with the QC. Unfortunately, the IR’s in Fractal have a different format which is not compatible with the QC. Unfortunately I was not successful. Capturing the amp + IR or just the amp is no problem. But if I only want to capture the IR, I end up with a very bright, digital overdriven sound.
Does anyone have any idea why this might be or what I need to do differently than when capturing an amp without cap?
Noise gates in the Fractal are off, low/high cuts too. The signal chain is the same as if I were only capturing the amp. Imput 1 and 2 are not clipped with the QC.
I am grateful for any advice.
Due capturing process (a lot of special peaks to test an analog Gear)
Try to lowering the gain in ir acquired capture controls, going out of distortion, and raisen up the volume compensating the level drop out
