Hi. This only happens in some of my presets and not others. So maybe I’m missing something here:
Example: I’ve pressed and held the Mix and Repeats parameters on the Digital Delay Stereo block on a straight Line 1 preset so that the block will be changeable between Scenes. Actually: all the parameters of the delay are in this state, including the Disable function. But when I make changes to any parameters in the new scene, they change on all other scenes using that delay, as well.
I’ve had a similar problem with gain on an amp in another preset…but the delay problem is popping up more often.
Thanks in advance.
