Archetype: Nolly Presets Thread
Thanks Teo, any feedback on them?
Hi Jim, it looks like you’re still recognized as a “new user”. If I remember right you should take some time reading some posts on this forum and you should be able to gain a level on the Trust Level settings.
Here is what I found out (you should find this info in a mail sent you by “discobot”, subject “greetings”):
" Get to trust level 1 by:
  • Entering at least 5 topics
  • Reading at least 30 posts
  • Spend a total of 10 minutes reading posts"
    After you reached trust level 1 you can post your attachments.
    Hope it helps!
Thanks! Will dig into the forum a little more.
Cheers,
Jim
Here is my metal rhythm present. Feedback welcome. Based on input from a couple of youtubers’ presets but tweaked to my taste. Perhaps a little too much gain for recording (I normally dial it back slightly) but great for jamming.
Rhythm.xml (6.3 KB)
and here is my lead (basically the same tone with a bit of delay/reverb)
Lead.xml (6.3 KB)
My setup is a Jackson Dinky custom (with EMG 81) going into a Scarlet 2 solo into Archetype Nolly.
I think you made a great work! I had to adapt some set up to my gear, maybe because I use a Prs 277 which is a baritone… Somehow I had low treble on the clean and a lot of bass in the distortion rhythm! And I had fun with the lead! :slightly_smiling_face: thanks for sharing!
Thanks for the feedback. The presets I made definitely need some tweakings, I made them with my old Epiphone Les Paul (with stock pickups).
Thanks for sharing them, I’ll give them a go and give some feedback.
Thanks for sharing, I’m gonna try it!
Thank you for this crazy sharing ! :star_struck:
Glad you liked them man!
HI :slight_smile:
Is it possible to get you to share this preset?
Thanks
Sorry for the delay! I’m uploading it
I upload also the Rhythm tone of Dream Theater Untethered Angel https://www.dropbox.com/s/awu8s8bsy7s3yeq/Untethered%20Angel.wav?dl=0 if u like it
And some As I Lay Dying tone https://www.dropbox.com/s/0fwp8aw66pmfmaj/AILD%20Remake.wav?dl=0
Godsmack preset https://www.dropbox.com/s/mmeifu5s22crupi/Godsmack%20Nolly%20Preset.rar?dl=0
John Petrucci Untethered Angel https://www.dropbox.com/s/1kl06x52m3j4dvp/JP%20Untethered%20Angel%20Nolly%20Preset.rar?dl=0
As I Lay Dying https://www.dropbox.com/s/irtho8nsnx3cq62/AILD.rar?dl=0
Let me know if they works, it’s the first i share so i hope i’ve done all right :slight_smile:
Nice PAtch … i’ve modified a little bit for my taste and used on a JP6 Music Man … thanks man …
Thanks a lot man!
The AILD is nice for my taste, i could use a tone like Polaris for a 7 string if you are bored :wink:
Glad you liked them guys! Yeah me too, depends on the guitar i use, i change a bit the parametric eq. I will share some other ones :slight_smile:
I’ve been messing around with the 4th amp for a Steve Vai type lead tone from the Alien Love Secrets era and this is what I’ve come up with so far. For my setup, it sounds pretty close to the solo tone on Die To Live which is the basis for the preset.
Enjoy!
SV Die To Live.xml (6.4 KB)
*Edit: The normal 1.01 Reverb/Delay bugs are still present so toggle on/off if the mix sounds too spacy.
I just made some other new presets for this awesome plugin:
  • 5 new lead presets based on a request I got on my YT channel, they were made to match the corresponding rhythm presets and provide some variety using 2 different guitar tracks. They are called:
    • ModMetal 3 - A3C3-421-414 (matching the Modmetal3 A3C3 - 57 - 421 rhythm preset)
    • ModMetal 6 - A3C3 - 57-57 (matching the modmetal6 - A3C2 - 57-57 rhythm preset)
    • ModMetal 7 - A4C3 - 57-160 (matching the modmetal7 - A3C3 - 57 - 421 rhythm preset)
    • Doom 3 - A3C1 - 414-57 (matching the Doom3 A4C2 - 414 - 57 rhythm preset)
    • Doom 3 - A2C2 - 57-160 (matching the Doom3 A4C3 - 57-160 rhythm preset)
  • 20 new rhythm presets, each one has 4 different cabs combinations, they are called:
    • Grind 1
    • Grind 2
    • Grind 3
    • Thrash 1
    • Thrash 2
As usual you can find them in the “Preset Vault” section on Honest Amp Sims Reviews site https://honestampsimreviews.com/preset-vault/, under Guitar Amp Sims - Neural DSP Archetype Nolly folder, here is the direct google drive if you’d like to download (free download) them https://drive.google.com/drive/folders/1JbJuAWN-9N-0JctixQ35R6dyDtCfkOXs .
If you’d like to download only the new ones just sort them by date.
Hope you enjoy!
Thanks for sharing these! I just got Nolly and its a great jumping point for me! Im still messing around and trying to find "my"sound. This def helps as a way to see how the amps shape!
