Hi All,
I was thinking about the capture process when it comes to capturing my pedals. At present, there is the option of a speaker block to monitor though, which makes sense when it comes to capturing an amp/amp head. However, when capturing pedals, the current process means having to set the pedal via an fx loop in a preset, then re-patch all cables to capture the setting you’re happy with. I think the whole process would vastly improve if an amp block was available along with the cab block.
My other reason being, a drive pedal through the fx loop doesn’t always sound the same as once the capture is in the preset and thus i find having to re-capture until i’m happy is more time consuming than it would be ifi was able to monitor through an amp as well as cab.
Be great to know if this would be useful to others.
