What is the solution, to get the loudness from youtube in the quad cortex harder. In youtube is it set on its hardest volume,also on the pc. But still not loud enough. I use the quad cortex as a usb-interface
More context needed…
Are you using your QC as an audio interface, with computer audio set to go through it? Does other website audio also have the same issue?
Does audio playback from any other programs (Apple Music, games being run through Steam, etc.) have the same issue?
Where is the volume knob set on your QC?
I’m not sure what you’re trying to do here ?
Youtube loudness and other streaming platforms usually comes in at about -14 LUFS.
This loudness is to make the volume friendly for different devices (telephones, earbuds computer etc).
Basically it’s a standard so as not to damage electrical goods.
So back to your question it could be you need to boost the Youtube stuff on a pc .
Hi, you can swipe down on the screen to access the USB input level. I had the same issue before noting that the USB input level was around -12 dB. Just turn that up snd you should be fine.
Yes I did so, thank you for the response.
Thank for youre response.
I have solved it.
In the i/o settings, the headphone hp level on 12.0 dB. And the multi out -3.0 dB.
Than the guitar volume and youtube sound level are in balance.
