Dear artists:
When I use the QC internal recording, I will often turn off the audio and then turn off the QC, every time there is a loud current, after updating the 1.10 system. There is almost no sound from my 1234 output port, but the display level is very normal. I don’t know if the rear interface is burned out or a software problem. Please solve it.i love you thank you
PS: When will China set up a maintenance point?!!!!!
I have the same problem,just output/3 sound very small,others is normal.
This problem is founded after I updated CorOs to 1.4.0 version. Yesterday I found this problem.
I test output 1, 2, 4, worked well,just 3 sound very small.
the quad cortex is quiet compared to other preamps. If your output meters are near the top and you still think it seems extraordinarily quiet, then I’d reach out to support. I think at full output of everything and pushing 0 dB on the output meter I get close to my other gear.
BTW 0 on the output meter isn’t clipping. You can really increase all the way up as long as you’re not hitting the internal limiter.
