The top is a 3mm thick piece of frost white plexiglass. The bottom of the enclosure has holes for brass inserts M2.5 or M3 so you can use long (30mm I believe) screws to attach the translucent cover. I used these same screws to attach the entire assembly to my pedalboard…
Hello cbellanga, hope you’re doing well. I thought your configuration was amazing and I repeated it in my set, I used it as inspiration. Except I’m only using the MIDI Captain, the QC obviously, the expression pedal, and the Shure. When I saw it I thought it was sensational. Could you pass the link to this pedalboard? Thank you very much.
Updated Quad Cortex board completed! After waiting months for a Temple Audio SOLO 18 that never arrived, I went with the Warwick RockBoard Tres 3.0. Next I need to sort out the Lehle functionality and I’m all ready for my next gig.
I apologize about the late response. The 1/4" dust plugs are from D’Addario and the XLR ones are from Neutrik. They can both easily be found on Amazon. I’m still on the hunt for good MIDI dust plugs.
