Hi everyone. Is there a way to control the Out Level , from the I/O settings via midi? That would be amazing if there was a CC that could trigger those levels Out 1,2,3,4. That way it would have a global volume control without losing any of the expression pedals.
I could just add an analog volume pedal before the input but midi messages would make it easier.
The only thing I think you could do is set the grid I/O how you prefer and change it via MIDI etc. If you are unable to determine a solution, check with support@neuraldsp.com and they might be able to direct you with your solution. Also, I believe 2.0 may include global volume and EQ which may help in your application as well.
