Midi out problem
Hi,
I’m trying to control the low-pass filter on a Chase Bliss pedal via MIDI out from my Quad Cortex. How do you set the Quad Cortex to send CC# via a DAW? I’m using Ableton Live, setting the MIDI out, and using a clip with an envelope to trigger the filter change, but nothing happens.
If I set it up the same way but with the sound card MIDI out, the filter moves. Also, if I set the expression pedal to control a CC# via Quad Cortex Control, it works, so I may be missing something for controlling by daw. All midi preferences are the same between soundcard and cortex.
With Ableton, I could control all the parameters with LFOs and envelopes, which is something I cannot do via the Quad Cortex Control app itself. Any advice would be greatly appreciated.
Thank you.
