As per subject, any volume control capabilities via midi?
Either master or individual outputs?
When playing a set where preset change automatically (midi) t’s not clear how I can get consistent volume
Thanks!
Thanks!
You can control a gain block in the chain to raise/lower the volume of your preset. I don’t think there is a way to control the master volume or specific preset volume otherwise. A gain block can be the easiest option.
Just takes a lot of attention to detail to make sure presets are all the same volume. You can use the output meter of the QC to check the level, or record the presets into a DAW and level match them all after checking what each preset is volume wise.
Fair enough, hopefully we get better Midi functionality at some point. I would love to be able to tweak devices via Midi, I think the axe fx lets you do that.
