Good afternoon, thank you for your product. Very good useful processor. Only it lacks functions for vocalists. Separate plugins of the application. As well as it is implemented for guitarists. Now many processors already use separate modules in their software only for vocalists, such as autotune, different types of reals and so on, I would like to add this to Cortex as well
Hi, there are a few existing requests for vocal effects. Check these out:
It would be good to specify a little more which kind of effect you’re looking for, and make a separate request for each.
We did get a pitch correction in 2024 with the release of CorOS 3.0.0. I don’t remember seeing anyone comment on whether it works well for vocals. Other than that, EQ and compression block types can be used for vocals as-is (along with reverb, delay, modulation, the whole kit).
I would like to separately implement a direct block (folder) of vocal plugins, yes, now there is a vocal corrector, there is a reverb, but all this should be looked for among other plug-ins mainly for the guitar. For example, HeadRush already has an emphasis on vocalists and the processor is presented not only as guitar but also vocal. I’m sure it can be implemented no worse here.
As a result, from the wishes to add a separate block with plug-ins for vocals, add there, pitch, harmoniser, reverb, doubler, delay, eho, eq. You can use all the plugins that are in Mantra
