This is literally the only thing standing in the way of perfection. Adding these effects will give vocalists a full suite of options for using this as an inclusive all in one unit, obliterating the competitive market across the board. Neural what are you waiting for?
Hello, the request below already has a lot of votes.
[If the harmonizer described below is designed to change vocal harmonies based on guitar chords, then it sure as heck should be able to harmonize based on a fixed key.]
Also, check out the Mini Voicer block.
Intelligent harmony and vocal tuning aren’t quite the same feature but they could probably be melded from the same algorithm to complete separate tasks. They are both much-needed!
