Using NC in the fx loop of an amp, how to increase output to boost a solo?
Hi everyone,
as the topic says, I want to use the NC as an Effect in the FX loop on an amp.
How can I increase the volume, to boost a solo, without capture- and IR-block?
I’ve tried to increase the volume via the gain-pot, but that didn’t work!
What would you suggest? Is this even possible?
Any help would be highly recommended.
Rock on, Bernd
Are you using a midi controller? I think that’s the best way. If not you could have, say the same FX chain in both Stomp 1A and 1B only with B having that boost already configured, maybe with a volume block, gain or comp.
Depends on how you are running it.
If you have an expression pedal, that’s another way. You can set it up to control certain parameters, like volume.
Hope it helps.
