I know it is possible to configure the footswitches in a 2 way mode (Left for 2 presets, Right for bypass).
I would like to have the choice to use the current sound of my amp with the Nano’s effects. Is it possible to set a preset without affecting the sound of my amp (wich I like very much for certain sounds) and retaining the effect section?
Yep, that’s actually how I use mine at the moment. Using the compressor and delay effects into my Deluxe Reverb. Capture and IR loader slots turned off.
Just make sure to set the level knob accordingly. Mine has to be set all the way up to get unison gain. Keep in mind the level is always affected, even when the Nano is on bypass mode.
OK. Thanks for your reply.
@Sabos : do you plug the Nano directly in front of the amp, or do you use the effects loop? I suppose I should try it by myself, but your thoughts are welcome.
