Thank you for taking the time to read and help if you can.
I’m trying to confirm if a Cioks DC7 would be enough for what I need. I see it comes with a ton of cables but I’m not sure if I need to purchase additional cables if in fact a DC7 would work. Here’s what I have:
Quad Cortex (12v, 3000mA <but I am led to believe 2000mA will work>, center negative)
Eventide H9 Max (9v, says “up to” 650 mA, center positive
Sennheiser G3 Instrument Receiver (12v, 400 mA, center positive)
Dunlop GCB95Q Wah (9v, 1.8 mA <is that right!?>, center negative)
Morningstar MC6 Controller (9-12v, 120ma, center pin negative)
I know the QC will work by daisy chaining outputs. Does the Cioks come with what I need to do that? Or do I need to purchase additional cables? Same with the Eventide and the Sennheiser receiver. These things are not just run of the mill power requirements as far as I can tell. Whereas I don’t have much concern for the Dunlop or the MC6 as it appears they really don’t need much power.
Thanks again!
Thank you so much for any guidance.
