User Templates
Would it be possible to create user templates for signals chains?
Like a rock template with the appropriate blocks, jazz template with the right blocks, etc…
This could be a good way to jump start preset creation.
You can use any existing preset as a template simply by starting creation by loading such a preset and then saving it to a free location. You can even set aside an area for storing template-presets so that you can give them meaningful names: rock, jazz, metal.
However, this of course will not work if you want to create something from a template on free line in existing presets. For such a situation, the following idea was proposed: Copying complex signal chains between scenes/presets
I don’t know if others would find this helpful, but I know that most of my presets I build myself have a lot of the same elements. It would be cool to have a “New preset from template” feature so new preset had all the items one would normally place in their presets (gates, eq, etc)
I know there’s the workaround of making a preset and then doing save as, but a template feature would be helpful, I believe.
“New preset from template” is an option that fractal units have,wish i can do that on the QC unit
