hi, I’m testing QC as a sound card with my M3 MBP on 15.3 Sequoia OS with Ableton Live and Hollyhock Usine.
I want the QC signal be the input to process it further and don’t want to hear the signal coming out from QC as it was in parallel but it seems I’m not finding where I can choose such option.
Many thanks
if you’re wanting a DI signal with no fx from the QC grid, Input 1 in your DAW should be the DI via USB from the Quad. Input 2 in the DAW will be the DI from the Quad’s Input 2. These are the default settings. Inputs 3 an up in the DAW will be the grid lanes w/ fx from the QC.
If you are aggregating other interfaces thru the Audio/Midi settings, those #s might change.
thank you, my idea is having the guitar processed by the QC feeding the input of the DAW.
Basically, I don’t want the sound processed by QC to reach the output by itself, I want it to stay in the DAW so to process it further and let it reach the output just after passing through the internal plugins.
Hope this makes sense
