CorOS Version: 1.01
Using a Late 2014 Macbook Pro (Big Sur) I am getting frequent cut outs in the audio when using the Quad Cortex as a USB interface. This is not happening with my brick-like 2010 Macbook Pro (Mavericks). When both devices are first turned on the audio might last for 1-2 minutes after which replugging the Quad Cortex the audio comes back for 5-10 seconds before dropout.
Checking the console I am getting HALS_IOA1Engine::EndWriting: got an error from the kernel trap, Error: 0xE00002EE
Steps to reproduce:
- Step 1 - Plug in audio interface
- Step 2 - Play audio briefly until it beeps and cuts out
- Step 3 - Be sad
- PRAM reset
- Turning both devices off and on, disconnecting from power and recconecting
- Moved back to Catalina, same issue occurs, same error
- Restarting Coreaudiod via terminal
