Hi all
i really need to know if i can import or capture the Fortin cali suite plug in into QC
Is it possible ? has anyone done this and how accurate the sound is ?
Thank you
Hi all
Thank you
Yes, you can capture any amp / drive plugin. You would need a separate audio interface and essentially follow the procedures detailed within this thread:
How to do a capture of a plugin?
Additionally, you can search here and or YouTube for capturing plugins with the QC.
The results are subjective, but depends on how you configure your gain staging to get the most accurate results.
Thank you very much for your reply. I understand that the QC can capture it, but I was curious to know if anyone has already done so.
It would have been helpful to know in advance before attempting it myself (as well as what to expect from the procedure).
Thanks again.
Glad to help! ![]()
Although I haven’t captured that specific plugin, you can search the NDSP cloud for Fortin Cali and multiple captures (as well as presets) will show up in your search results that you can try. Some are amp only, some have a cab and or drive baked in etc., you would just need to try and see what you like for your purposes.
Many are capturing plugins, I captured some of my Mercurial and Nembrini plugins and was definitely pleased with the end results. Depending on your configuration, YMMV
ok i will follow these steps thanks alot!
