Unwanted fizz with medium to higher gain presets
Has anyone experienced a slight fizz noise when using medium to high gain presets? It is fairly subtle and can be reduced by lowering the gain but it still remains and is a little annoying. It becomes particularly noticeable when using the compression/overdrive effects that came with the 2.0 update. Any suggestions to remedy this will be greatly appreciated.
Thanks!
JW
I tend to use an EQ last in my effects chain and filter out anything above 8K, same with in my cabinet settings. There is still a little static, but you don’t really hear it in a mix
