So I downloaded a ton of neural captures from the site and some are pedals. Now Im not referring to the amp sim type Pedals here but things like a a real effect say a compressor or something. Where do you open these up on the nano. Are they only used to replace where you’d put and amp capture for example. I dont see them in the modulation or reverb type slots for example what am i missing ? cheers
Well, this is another somewhat sensitive subject.
We want the capability to add the captured pedals inside the signal chain.
So we can put a pedal capture before an amp capture kind of thing.
This is not possible at the moment. You can not have two captures inside Nano.
Only one. And that is only inside the capture slot that is used for amps.
So if you put a pedal capture in there that is the only capture you can use.
This is so unfortunate but I’m hopeful that it will change in the future.
thanks it kind of makes sense but especially for guitarists it must be a biggy. I am only using it for Bass and accidentally noticed it I was only thinking as capture as amps originally and some people name them in ways that dont describe them well
It is possible to capture pedals and use it instead of an amp I think. I have not done that.
