Add another neural capture slot option to the chain?
That way we could use all the neural capture pedals available in the cloud.
We don’t have the possibility to add overdrives or different type of pedals. With one more neural capture slot we can use all type of pedals. So important to keep clean and reusable the captures.
Definitely need this. I think being able to use only one capture block would make it hard to use most captures that are already on the cloud.
Drive pedals are a big part of the capture cloud, and I would love to use it with the amp capture.
I know this is a highly requested feature, but we hope it gets heard, as it could make this device already amazing even better!
Many users, including myself, would love to see the ability to use factory/captured overdrives or distortions pedals on the Nano Cortex. Currently, the 5 LEDs on the right side of the device clearly indicate the following effects in the signal path:
  1. Noise gate
  2. Pitch shifter
  3. Modulation
  4. Delay
  5. Reverb
Given this setup, adding a standalone OD/DST block might break the visual and functional consistency, as it would introduce a sixth effect.
A potential solution would be to integrate the OD/DST block as a “sub-block” within the amp block, allowing users to select it and place it in either PRE or POST positions. This would preserve the visual simplicity and still provide the additional functionality users are asking for.
Thank you for considering this request, it would be a fantastic addition to the workflow for both live performances and studio work!
And a big thanks to the Neural DSP team for making the best of the best!
