I’m able to launch in standalone mode, but I’m unable to activate the audio Unit in garageband. I get the error message:
“.tmpXXXXXX” can’t be opened because Apple cannot check it for malicious software."
I then get an option to open in finder, followed by:
“A fatal wrapper bootstrap error happened”
and finally:
“The Audio Unit “Fortin NTS ” could not be loaded for your project, and may need to be updated.”
I’ve tried adding a sandbox key to:
‘/Library/Audio/Plug-ins/Components/Fortin NTS Suite.component/Contents/Info.plist’
then forcing a plugin re-scan but to no avail. I followed some docs here: https://developer.apple.com/library/archive/technotes/tn2247/_index.html
I’ve also read the troubleshooting docs here, and few that were based around catalina breaking with other software. Is there a known workaround for this issue?
