Hi all, I’m new to QC and I needed to have some footswitches activated by foot while having the QC on the table.
So I checked if I can use expression inputs to control effects bypass, and it can be done.
Just use an external footswitch as Boss FS-5 or FS-7.
While editing the effect, tap on the three dots menu icon on left, then tap “Assign Expression Pedal”, select expression port 1 or 2, then enable “BYPASS” and set following parameters:
“Latch emulation” to ON
“Switch on” to SWITCH
That’s it.
If your external footswitch is correctly connected, pressing it will enable and disable the effect.
Have fun
Roberto
