Are these captures including a mic’d cab or are they direct? I originally had added a cab but with headphones it sounds like it shouldn’t have a cab block in the signal path. Maybe it is the result of trying to monitor it at low volume with headphones that ‘no cab’ sounds better?
also, trying to search the cloud app for a capture named “TW’s Mad Pro 2” and I get nothing…same with just using “TW’s”…but if I use “Tw” in the results you find “TW’s Mad Pro 2”. Unusual and frustrating behavior for a search!
