Hello I have a sound problem with the Quad Cortex, my guitar di signal is also heard with the distortion sound processed at the same time when I’m plugged into my transistor power amp, my guitar goes in from the in1 and my PA in 3. any solutions to solve this problem?thanks.
can you show us your preset? You probably have a parallel Lane unmuted. When you bypass fx blocks, the signal still goes thru them
I will study this more closely I will come back if I do not find the solution thank you for your answer.
