Hello,
I wonder if the temple audio AC Module would work for the Quad cortex?
Hello,
Hey @rdavles81. It won’t work if you connect it directly. That unit is used to feed other power modules (such as the Hi5 MOD). Also, the QC requires 12VDC and 3A (negative polarity). Apparently, the one in your link is for 100mA.
You can check the specifications on page 107 of the user manual.
