Tap Tempo control via MIDI with FCB1010
I’ve taken the plunge into midi control with my Neural DSP plugins—utilizing the Behringer FCB1010. I did find a good configuration software (Mountain Utilities), and lots of good videos guiding me thru configuration, pairing, etc.
I’ve successfully applied all this info to control preset changes, effects toggled on and off, etc.
I’m still having trouble getting the FCB1010 to properly communicate to the plug-in to set TAP TEMPO for the delay pedals in my plugins.
I’m not sure what kind of function to configure the FCB1010 for, and I’m not sure how to map it properly on the plug-in side. Any help is appreciated.
Additionally, for some reason, only my expression pedal A is working properly when I want to assign it to something like output volume master or maybe delay/reverb mix. But expression pedal B isn’t working quite the same, even though I’ve set it up the same way. Any help there would be greatly appreciated, too.
