Currently it just lets you switch presets with unsaved changes, and I lose changes I make while distracted and at practice all the time this way.
- Maybe make it so that if you try to switch presets with unsaved changes, you get asked if you want to save first.
- If you reject that idea, then make it so that it saves the preset every time I press a “check mark” like to exit a block and save changes.
- If you reject that idea then it must be so that people can A/B saved versus revised sounds. In that case you’re missing a button at the top by the preset name to compare the saved sound to the modified sound. Otherwise your setup makes no sense.
