I have the SP25M Pro Aero (the momentary switch version) and I’ve had issues with the compatibility using the switch. The QC can only accept a TRS cable for the switch but the pedal uses a TS jack. This is probably why mission engineering has its own pedal for QC.
Separately if you want suggestions, I’ve read good things about the Lehle Dual. Slightly more pricey than the Mission Engineering but seems like you’d have less hassles and its newer technology.
