Sound «thru» when comparing amp and capture, and impedance on input 2 when capturing line signal
Question 1: I have captured an amp and have the miked amp on one channel and QC on another on my mixer. When I change between source and capture before saving, QC sends audio both to the amp and QC monitor channels in both cases. That means I have to mute one of the channels on my mixer not to monitor both at the same time. Shouldn’t there be a mute function that mutes the signal sent to the amp while auditioning the capture and vice versa?
Question 2: I use an external mic preamp, so the signal captured in input 2 is a line signal. Should I use a reamp box here and use the 1M impedance, or should I just set the impedance lower, in that case how low?
