For certain parameters moving the pots causes a large jump in values. While I understand how this can be useful it also leads to a less fluid workflow so,etimes. As an example: the values for the newly introduced room mic volumes jump from -21.8 dB straight to an inaudible -40. Similar issues exist with certain eq frequencies. While you can tap to enter the number manually it would be nicer if you could press a pot or other “button” to enable a “fine tuning” mode to more accurately dial in the parameter for the affected parameters with larger jumps in values.
